kth286
Nope it is footwell mounted as I describe. Unfortunately, there are significant differences between 93 - 96 W124 UK spec cars in terms of the alarm/immobiliser and other cars intended for other markets such as North America. In the early 90s the UK was suffering from lots of car thefts and insurance companies insisted on specific approved alarms which lead to MB partnering in the UK with Scorpion and branding it as MBSS. The unit I have in my Cabriolet is the more sophisticated version but I also had a 94 W124 E320 estate that had the less sophisticated MB Scorpion unit which worked by rf remotes as Dec shows early in this thread. Interestingly enough that unit failed too and I have a brand new unit that a bought as a spare still in the box
Yes - the later 124 (starting model year 1996) the remote central locking
is enhanced with so called drive authorisation system (DAS), stage 2.
Previously a starter lock-out system is installed which interrupts circuit 50 to the starter.
Boomtings:
I am not suggesting main earth W1 behind cluster is loose enough to shake about going over bumps. If it is corroded, it will be causing a high voltage resistance depending on weather conditions, causing the voltage to be too low to operate circuit relays & components on occasions - just like the fuses in the fuse boxes of 124s corrode and break circuits intermittently.
