Have replaced with new - crank posn sensor, plugs, leads, distributor cap, rotor and coil a couple of months ago when I decided to put car back on the road. It had been sat on driveway for approx 1 year and had only been started occasionally. Car was running after these changes but with irregular idle pulsing from about 500-1700 rpm and occasionally stalling. Fuses were all checked turned and continuity checked then, and i have repeated this week. Earth points and battery terminals taken apart cleaned reassembled. (Have also tried adding a jump lead direct from engine to battery negative to ensure good earth). All wires at coil were also cleaned when coil was changed.Have you change the distributor top and the rotor along with ht leads and spark plugs . Check you fuses in the fuse box - give them a turn for now. Look at the wires on to the coil for corrosion .And look at all the vacuum pipes for splits .
Sorry I wasn't totally clear, the old fpr had a couple of dodgy looking solder joints and it was replaced to eliminate this as the cause. When the car is running again I will switch back to the re-soldered original to confirm it is functional and pack the new item away as a spare or resell it. Cost of the relay wouldn't get anywhere near to minimum charge at any garage I know of anyway.How much did he save buying a FPR he didn't need? Enough to get it diagnosed by someone who knows what they're doing?
Thanks for the info - they are the only place that I do know of. Contacted them a couple of weeks ago and they had no space, waiting on price to get car transported to them should it prove necessary.As you are in Hampshire have a chat to PCS in Horndean. They sort any issues on our 124 and know their stuff on older Mercedes. Price is very fair too.
I'm using an electronic copy of manual from a link posted on here IIRC. Mercedes Benz Model 124 - M103 Maintenance ManualsDave do you have a manual ?. You said you had replaced the CPS was this fitted to the rear or to the front .Do you see this on the top of the engine [picture ] if so remove the item and clean it out with white spirits shake it or let it sit over night .After do check and make sure you fit the pipes back in the right place after you do this .2 bolts on the top and a plug on the rear to take it out .Picture to follow . It wont hurt to clean it out .
Spark plugs were same as were in the car when I got it about 5yrs ago NGK BP6EFS had no problems with them on gas or LPG. Dizzy & rotor I'm pretty sure were Beru (had dodgy GSF parts before that which were rubbish) When it was running better there wasn't any tracking visible. The cps (part no. 70610200) and coil I dont know but going by the prices not bosch. All the parts came from german supplier Partex Global GmbH. The rev counter is working fine (petrol Gauge is a bit jumpy at lower levels but had the same on one of my old 190e's sticky float?). I am pretty confident the ignition components are all ok - good strong sparks when cranking and it fires up every time.Yes you do have another sensor on the front of the engine but not a CPS ,some people dont know that the one is not the same as the other just wanted to check if it was the right one -looks like it is .. ,i too have the M103 .Can you try a smoke test for leaks in the system .One more check when engine stops look at the rev counter see if it moves when you try to start the engine .And did you fit part number for part number -not close enough but the right number parts for the m103 . Bosch parts only or Beru for ht side.
Hi, good to see you are still on here.Dave this free manual might be helpful to you ,,most of us w124 owners have it . Google this > Model 124 Maintenance Manual Index <
Have to bridge the fpr to get any build up of pressure. The initial few seconds of pumping wont increase the pressure much above the 3 bar, fuel pump running continuously (fpr bridged) same 3 bar, which I assume is maintained by the accumulator when ignition is off. 3 bar seems to be the maximum pressure my fuel system will hold even though the pumps will push out 10 bar.You wont get a correct reading with the fuel pump relay bridged ..Why did you bridge the FPR after you fitted a new one . Fuel presure is upper chamber = 5.7 bar and lower chamber = 5 bar .
