Headlamp wipe / blower
Well, replaced both wash wipe motors below headlights with salvage ones from Dronesfields. Turned on lights (not wipe washer at this stage), and number 3 fuse blew, after a quick squirt of water! The motors and squirt should not happen until wash wipe activated, so clearly I still have a problem. Can somebody please help!!! I have used up my supply of fuses!
Unrelated (I hope), the blower is also operating intermittently. It works fine some times and fails to come on at other times. Some times it comes on several minutes after car has been running. The only pattern I can detect is that it often does not run if engine is hot from a previous run. The left hand dial on the centre console works fine. Looking back through the car's service record, it was replaced 2 years ago at a cost of £161.56 parts and £80 labour (exc Vat) at 94,000 miles (cost of total job £283.83 at an Independent MB Specialist). The car has now done 130,000 miles.
Any body any ideas what might be wrong? I have checked previous threads, and seen something about fuse holder expansion. The relevant fuse seems to be a 10amp blade in a neat clear plastic box under a plastic black cover with some relays behind the plastic cover behind the battery, but I cannot see anything wrong with it or its holder.
Suggestions welcomed!
John
