It does seem a rather Biblical approach to the problem.
You want something like this here… Mercedes * Steering ignition lock * w124 124 230 250 400 320 280 e-class | eBay …IF yours is an automatic?
My point was that you can get it out of the car without removing the steering column or anything, even the steering wheel can stay in place.
It is literally 60 seconds to grind down the pin with a dremel and then you can simply slide the lock off.
That’s what should have happened alright but as Bob says, he’s not a mechanic.
If he buys the eBay part then all he has to do is dermel out the pin as per your picture.
Will he need a new pin or can it be fited without the pin?
Dec
Erm...he said his local Mercedes specialist came over specially and did this....
I wouldn't worry about replacing the pin. It's only there to make it slightly harder for thieves trying to disable the steering lock. They won't know the pin is missing without removing the panel.
Instead of doing all of this you could have saved yourself a whole lot of time and simply done what I said in my post earlier. Simply cit around the black outer sleave of the barrel and the barrell will almost fall out.
Even if you ignored that and wanted to get the lock assembly on a bench to work on, you could have simply done the following in the picture I've attached below.
As it is you've now damaged the base of the lock assembly. This wont be cheap and additionally, getting the ignition wiring back in place and in the right locations is going to be a whole heap of fun.
The only reason I can think of for a mercedes specialist to do it that way is so as to be able to charge more for the job... either that or he's not much of a specialist.
The chunk of metal that sits behind the ignition is the ignition switch or connector as it is called in this video here… W124 ignition assembly - YouTube
If you bought the above you would have a new and separate ignition key that won’t fit the doors but cheaper than new from dealer.
Dec
Would it not be as handier to buy the whole thing as in picture below, save all the dremel’ing?
Dec
Dec
That’s exactly what I thought but wasn’t sure if the pin’s presence is important, thanks for clarifying that.
What I mean is that he wouldn’t have been told to cut the lock in the way that he did, that was his error, it’s not too clear what actually happened and why it was done in this way. Either way, he will be able to rectify the fault for around £40 and any further advice is here if he needs it.
Dec
Yesterday i bought the steering lock/barrel/key from three pointed parts on ebay. This morning i got an email from Rob saying that there was a mistake in the listing and that the part wasnt available, along with a paypal refund. So this afternoon will be spent searching for mercedes breakers and ringing/emailing to try and find what i need.
Any help, leads, phone numbers, anything will be greatly appreciated.
Thanks again Dec for the continued help.
