>> anything else useful to do while this little lot is apart?
- Make sure the vacuum pipes and connections for the resonance flaps, variable valve on the IP, and the connection to the vac pipe which goes down to the modulator on the gearbox are in good condition
- Make sure the resonance flaps move freely, and their diaphragms are sound
- Check the engine wiring harness for the condition of the insulation - I found the insulation was cracking up near to the coolant temperature sensor near the back of the cylinder head, and in the wires connected to the resonance flap changeover solenoids.
- Check and rectify any leaking IP gaskets. This is one I missed, the rear gasket on my injector pump is leaking oil, and so, next time the manifold comes off, I'll be repairing that
- lubricate the ball ends of the throttle linkage with a little ATF
