SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
hi
it appears my new W124 estate has duff rear wheel bearings. a big
anyway, looking at this "how to" here:
PeachPartsWiki: Rear Wheel Carrier Removal (Rear Wheel Bearing Change)
it looks reasonably straight forward to remove it all and take it to a garage to press in the new bearing.
when i remove it as per the article - what happens to the suspension spring? do i need to keep a jack under the lower arm to support it????? there isnt any mention of this in the article
also, i've read that it just may be possible to remove the old bearing and use a vice to press in the new one - any advice on this???
i need to do BOTH sides of the car so taking it to a garage to do the work is going to kill my wallet so i need a DIY solution!!!
cheers
derek
cheers
derek
