DriftworksJames
Wondering if anyone can shed a little light on a problem I'm having.
Over the last couple of months I spent driving my 1988 260E around I noticed every now and then it would misfire when pulling away at low revs, but would then be fine for the rest of the rev range. This only happened every now and then.
I've left the car sat for 2 months and it's started fine, but since then it's misfiring all the time over about 2000 revs it seems fine, but less than that, it's not firing on all cylinders it seems.
I took it for a wash and it just wouldn't start afterwards, turned over fine and got spark and fuel up to the injector control box thingy with all the pipes coming out, but just turned and turned and wouldn't fire. It was a pressure washer, but I was very careful not to blast it through the grille and the engine bay wasn't wet. After waiting 30 mins for a friend to come and tow home I gave it 1 last go and it started ok, but is misfiring badly under 2000 revs all the time now......
I suspect it's either a damp/worn/knackered rotor or dizzy cap or something up with the fuel injector control box thingy.
Anyone had a similar problem?
thanks,
James
thanks,
James
