W140 coupe 1994 engine
wdb
near PETERBOROUGH
280GEL (1990), E 320cdi Estate (2000), cl500 (1995)
My 1994 manufactured, 1995 registered S500 Coupe with 119.970 engine, with twin distributors, coils and Bosch LH ignition has developed vibration and noisy engine between 1500-2000 revs.
No obvious problem below and above these revs. The vibration is quite severe and can be felt when sitting in the stationary car and I am now quite worried!
I have changed both distributors and rotors, plugs, airfilters, intake air and engine coolant temperature sensors but no change.
I have wondered about the ignition leads but they appear quite new ( I have had the car for about 6 months and do not now when they were last renewed).
Any ideas out there please?
I had not considered this but will investigate. Thanks.
Good lead Ian: it looks as if the engine is riding on the frame! So that could cause the vbration at a certain rpm range.
I gather that it is not easy to replace the engine mountings due to the lack of access space to the top bolts?
Has anyone done this job?
Many thanks!
