W201 Engine mounts
Will
Hardcore MB Enthusiast
Surrey
GL63 AMG / SL500 / B250e / Porsche 911
Quick question here,
When MB supply engine mounts for these cars they differentiate between cars with and withiout air conditioning.
I'm assuming the type for cars with air con are slightly beefier to cope with the extra weight/load? Is that correct or are they a different physical size etc?
Is there likely to be much difference from a fitting point of view and will it adversely affect the operation?
Just curious ;)
Will
They are to cope with the additional weight. Non a/c ones will wear out more quickly.
Cheers guys - as I assumed, I guessed they'd all be pretty similar bar a little extra strength for the air con types.
Thanks,
Will
