derin100
The passenger rear window on my W201 2.6 isn't working.
I've established that there is power getting to the motor...and you can even feel it getting warm after trying to make it work on the switches for a while.
I can't figure out how to get the motor and regulator out. I've taken off everything except I can't figure out how one releases it from the the actual glass at the top. The window is in the "Up" position so it's really difficult to even see how it's attached to the guide rail.
Also, looking at the wire cable, on one side of the big spool the cable is really taut but on the otherside it's a bit slack. Is that how it's meant to be?
I don't mind buying a replacement regulator and motor if needs be but I just can't figure out how to get the old one out.
TIA !
TIA !
