DITTRICH
When started at ambient temperate "from cold" the revs initially rise to 1,400ish and then stick persistently at 1,200 for a minute or two and thereafter gradually over the next minute or two reduce to around 800.
I think this is wrong. Why?
Because before around 2 years ago, the engine would immediately settle down at 700 - 800 after the initial rise to 1,400.
The car is 1999 vintage - facelift - and has done 108,000 miles. None of the various sensors have been replaced. The garage did instal some new "throttle slide actuator" or some such thing £525+VAT to see if it was the issue - it wasn't. I started the car at the garage today in their presence and it still sticks at 1,200 even at 24.5 deg c ambient temperature from cold.
I was told that this "throttle..." thingie controls the idle speed and takes its commands from the ECU. The ECU gets inputs from all over the place including:-
1 Lambda sensor in the exhaust
2 Mass airflow sensor in the air intake pipe
3 engine temperature sensor (radiator? engine?)
4 crankshaft position sensor?
Is this list complete? Are some of the above irrelevent?
Given that the behaviour seems to disappear after 3 minutes from cold, something is obviously working better as it warms up. The question is WHAT?
The techs have had the car hooked up to diagnostics and looked at the startup characteristics from cold but everything is "in spec" they say. However, I know that sensors fail over time and slowly go "out of spec".
I know very little about cars but I do know that £525+VAT is alot of money.
All advice from man on't'internet gratefully received.
I'm picking the car up today at 6pm for the weekend and its going back on Monday. Only difference, this time I hope to tell them what to do, rather than let them tinker by themselves.
Les
Les
