W202 C250 Sport Lowering
86Jake
Cheshire
C250 TD Sport
New to the forum on my second W202 (previous C180) now on W202 C250td W-reg but I'm having trouble finding decent and concise information on lowering a sport?
I'm looking for maybe another -20 to -30mm more than standard sport?
Can anyone point me in the right direction I think springs would be good or springs and shocks if needs be.
I've read about the different spring seats I've dealt with these on other vehicles previous but they don't give sufficient drop also as its a sport I'm presuming they are thinnest already?
Jake
Yeah thats what I was thinking but does any one have any idea which ones ? or reccommend any?
Jake
Sport has shorter shocks and springs but the spring perches are determined by equipment level to ensure same ride-height across the range.
250TD is likely the heaviest engine so if you have aircon, automatic and leather from the factory it probably has the thickest spring perches. You'll only drop 15-20mm maybe per corner but they're under a tenner each. Post your VIN, list all your factory options or take a look at the top of the springs (front is easy, rear more tricky) to determine which perches you have.
Well its C250 TD with aircon leather etc so ill have to have a look tonight then where abouts on them do they tell you the numbers?
Jake
There are pimples on them, the number of pimples is the number of the perch.
I have a full set of new #1 perches (thinnest), I brought for my car without looking at what was on it already!!
Once I looked, I already had #1's on there!
Had to order them in from the Stealer so cant take them back!
They are not too bad to fit, Front ones I used a spring compressor, and back ones, support lower arm with a jack and take the bolt out and lower gently and the spring comes out.
Jake
The perches/shims/pads (whatever!) have little rubber bumps moulded into them so you can tell without looking if needed, it's on the outside of the spring IIRC. I took a pic and posted it on the forum a few years ago but can't find it right now, will search again later.
If you ever wondered why MB parts depts are reluctant to look up this info, here is why!
Front suspension:
Code:
002 TO ASCERTAIN THE FRONT SPRINGS,PLEASE ADD UP IN THE CHART BELOW THE NUMBERS OF POINTS OF THE RESPECTIVE MODEL AND
002 OF THE SPECIAL VERSIONS INSTALLED
002 ==============================================================================================================================
002 MODEL POINTS CODE SPECIAL EQUIPMENT POINTS
002 202.018 26 580,581 AIR CONDITIONER 8
002 202.020 28 420 AUTOMATIC TRANSMISSION,DIESEL ENGINE 4
002 202.022 36 420 AUTOMATIC TRANSMISSION,GASOLINE ENGINE 3
002 202.024 38 228 ADDITIONAL HEATER 4
002 202.025 35 412,414 SLIDING ROOF 3
002 202.028 54 471 ACCELERATION SKID CONTROL 2
002 202.120 29 221,222,241,242 ELECTICALLY ADJUSTED FRONT SAET 2
002 202.121 32 934 TAXI DISTRESS ALARM SYSTEM 2
002 202.125 44 480,211 SELF-LEVELLING DEVICE/ASD 1
002 202.128 53 481 UNDERSHIELD (STEEL PLATE) 1
002 600 HEADLAMP WIPER/WASHER 1
002 RADIO 1
002 291 CO-DRIVER'S AIR BAG 1
002 682 FIRE EXTINGUISHER 1
002 CHART OF FRONT SPRING RUBBER PADS
002 TOTAL OF POINTS FRONT SPRING PAD PAD
002 STANDARD SPRING H.D.SPRING FRONT SPRING BLUE FRONT SPRING RED
002 SUSPENSION SUSPENSION
002 -34 -25 202 321 00 04 201 321 09 84 201 321 10 84
002 35-40 26-31 202 321 00 04 201 321 10 84 201 321 11 84
002 41-46 32-36 202 321 00 04 201 321 11 84 201 321 12 84
002 002 47-52 37-42 202 321 01 04 201 321 09 84 201 321 10 84
002 53-58 43-48 202 321 01 04 201 321 10 84 201 321 11 84
002 59-65 49-55 202 321 01 04 201 321 11 84 201 321 12 84
002 002 66-72 56-61 202 321 02 04 201 321 09 84 201 321 10 84
002 73-79 62-68 202 321 02 04 201 321 10 84 201 321 11 84
002 80-86 69-75 202 321 02 04 201 321 11 84 201 321 12 84
002 002 87-94 76-94 202 321 03 04 201 321 09 84 201 321 10 84
002 95-102 95-102 202 321 03 04 201 321 10 84 201 321 11 84
002 103- 103- 202 321 03 04 201 321 11 84 201 321 12 84
002 CHART OF FRONT SPRING RUBBER PADS "SPORTS UNDERCARRIAGE" "ESPRIT" BM 202.018,202.020,.022,.024,.025,.120,.121,.125
002 FRONT SPRING BLUE FRONT SPRING RED
002 -29 202 321 14 04 201 321 10 84 201 321 11 84
002 30-35 202 321 09 04 201 321 11 84 201 321 12 84
002 002 36-43 202 321 09 04 201 321 09 84 201 321 10 84
002 44-49 202 321 09 04 201 321 10 84 201 321 11 84
002 50-55 202 321 09 04 201 321 11 84 201 321 12 84
002 002 56-61 202 321 10 04 201 321 09 84 201 321 10 84
002 62-67 202 321 10 04 201 321 10 84 201 321 11 84
002 68-73 202 321 10 04 201 321 11 84 201 321 12 84
002
Copyright Daimler AG, 22/11/11 13:15, EPC 1.28.1.1, DW 11/2011 Delta 2 Page 1
002 002 74-80 202 321 11 04 201 321 09 84 201 321 10 84
002 81-87 202 321 11 04 201 321 10 84 201 321 11 84
002 88- 202 321 11 04 201 321 11 84 201 321 12 84
002 CHART OF FRONT SPRING RUBBER PADS "SPORTS UNDERCARRIAGE" "ESPRIT" BM 202.028, 202.128
002 -54 202 321 12 04 201 321 09 84 201 321 10 84
002 55-61 202 321 12 04 201 321 10 84 201 321 11 84
002 62-68 202 321 12 04 201 321 11 84 201 321 12 84
002 002 69-72 202 321 13 04 201 321 09 84 201 321 10 84
002 73-80 202 321 13 04 201 321 10 84 201 321 11 84
002 81- 202 321 13 04 201 321 11 84 201 321 12 84
002 002 ==============================================================================================================================
048 Up to ident. no.:
048 A 384233
048 F 369713
100 ONLY APPLICABLE TO:
100 A 202 321 00 04, A 202 321 01 04,
100 A 202 321 02 04, A 202 321 03 04,
100 A 202 321 09 04, A 202 321 10 04,
100 A 202 321 11 04, A 202 321 12 04,
100 A 202 321 13 04, A 202 321 14 04
Rear suspension:
Code:
003 TO ASCERTAIN THE REAR SPRINGS,PLEASE ADD UP IN THE CHART BELOW THE NUMBERS OF POINTS OF THE RESPECTIVE MODEL AND
003 OF THE SPECIAL VERSIONS INSTALLED
003 ==============================================================================================================================
003 MODEL POINTS CODE SPECIAL EQUIPMENT POINTS
003 202.018 27 550 HITCHING MECHANISM 5
003 202.020 28 412,414 SLIDING ROOF 3
003 202.022 32 287 REAR SEAT BENCH,DIVIDED 3
003 202.024 38 211 AUTO. LIMITED-SLIP DIFFERENTIAL 3
003 202.025 38 673 HIGH CAPACITY BATTERY 2
003 202.028 32 420 AUTOMATIC TRANSMISSION 1
003 202.120 27 430 REAR SEAT BENCH HEADRESTS 1
003 202.121 27 480 SELF-LEVELLING DEVICE 1
003 202.125 27 934 TAXI DISTRESS ALARM SYSTEM 1
003 202.128 35 810 SOUND SYSTEM 1
003 818,819 CD CHANGER 1
003 003 ==============================================================================================================================
003 CHART OF REAR SPRING RUBBER PADS W/STANDARD SPRING SUSPENSION BM 202.020, 202.022,.024,.025,.028,.121,.125,.128
003 TOTAL OF POINTS REAR SPRING PAD PAD
003 REAR SPRING BLUE REAR SPRING RED
003 -29 202 324 05 04 201 325 09 44 201 325 10 44
003 30-36 202 324 05 04 201 325 10 44 201 325 11 44
003 37-43 202 324 05 04 201 325 11 44
003 003 44-48 202 324 14 04 201 325 09 44 201 325 10 44
003 49-55 202 324 06 04 201 325 10 44 201 325 11 44
003 56- 202 324 06 04 201 325 11 44
003 CHART OF REAR SPRING RUBBER PADS W/STANDARD SPRING SUSPENSION BM 202.018, 202.120
003 -33 202 324 12 04 201 325 09 44 201 325 10 44
003 34-41 202 324 12 04 201 325 10 44 201 325 11 44
003 42- 202 324 12 04 201 325 11 44
003 CHART OF REAR SPRING RUBBER PADS W/HARDER SPRING SUSPENSION BM 202.020, 202.022, 202.028, 202.121, 202.125
003 -30 202 324 14 04 201 325 09 44 201 325 10 44
003 32-38 202 324 06 04 201 325 10 44 201 325 11 44
003 39-45 202 324 06 04 201 325 11 44
003 003 46-50 124 324 21 04 201 325 10 44 201 325 11 44
003 51-57 124 324 21 04 201 325 11 44
003 003 58-59 202 324 15 04 201 325 09 44 201 325 10 44
003 60-67 202 324 15 04 201 325 10 44 201 325 11 44
003 68- 202 324 15 04 201 325 11 44
003 CHART OF REAR SPRING RUBBER PADS W/SELF LEVELLING DEVICE
Copyright Daimler AG, 22/11/11 13:17, EPC 1.28.1.1, DW 11/2011 Delta 2 Page 1
003 -37 202 324 07 04 201 325 09 44 201 325 10 44
003 38-43 202 324 07 04 201 325 10 44 201 325 11 44
003 44-49 202 324 07 04 201 325 11 44
003 003 50-56 202 324 08 04 201 325 09 44 201 325 10 44
003 57-62 202 324 08 04 201 325 10 44 201 325 11 44
003 63- 202 324 08 04 201 325 11 44
003 CHART OF REAR SPRING RUBBER PADS " SPORT UNDERCARRIAGE""ESPRIT"BM 202.018,.020,.022,.024,.025,.120,.121,.125
003 -33 202 324 09 04 201 325 10 44 201 325 11 44
003 34-40 202 324 09 04 201 325 11 44
003 003 41-45 202 324 10 04 201 325 09 44 201 325 10 44
003 46-52 202 324 10 04 201 325 10 44 201 325 11 44
003 53- 202 324 10 04 201 325 11 44
003 CHART OF REAR SPRING RUBBER PADS " SPORT UNDERCARRIAGE" "ESPRIT" BM 202.028, 202.128
003 -36 202 324 11 04 201 325 09 44 201 325 10 44
003 37-45 202 324 11 04 201 325 10 44 201 325 11 44
003 46-53 202 324 11 04 201 325 11 44
003 003 54-58 202 324 12 04 201 325 09 44 201 325 10 44
003 59-66 202 324 12 04 201 325 10 44 201 325 11 44
003 67- 202 324 12 04 201 325 11 44
003 CHART OF REAR SPRING RUBBER PADS "SPORTS UNDERCARRIAGE "ESPRIT" WITH SELF-LEVELLING DEVICE"
003 -33 201 324 28 04 201 325 09 44 201 325 10 44
003 34-39 201 324 28 04 201 325 10 44 201 325 11 44
003 003 40-45 201 324 28 04 201 325 11 44
003 46-53 124 324 27 04 201 325 09 44 201 325 10 44
003 54-59 124 324 27 04 201 325 10 44 201 325 11 44
003 003 60-61 202 324 13 04 201 325 09 44 201 325 10 44
003 62-69 202 324 13 04 201 325 10 44 201 325 11 44
003 70- 202 324 13 04 201 325 11 44
007 TO ASCERTAIN THE REAR SPRINGS,PLEASE ADD UP IN THE CHART BELOW THE NUMBERS OF POINTS OF THE RESPECTIVE MODEL AND
007 OF THE SPECIAL VERSIONS INSTALLED
007 ==============================================================================================================================
007 MODEL POINTS CODE SPECIAL EQUIPMENT POINTS
007 202.018 AUS 28 412,414 SLIDING ROOF 3
007 202.022 AUS 34 287 REAR SEAT BENCH,DIVIDED 3
007 202.028 AUS 34 211 AUTO. LIMITED-SLIP DIFFERENTIAL 3
007 202.125 AUS 31 673 HIGH CAPACITY BATTERY 2
007 420 AUTOMATIC TRANSMISSION 1
007 430 REAR SEAT BENCH HEADRESTS 1
007 480 SELF-LEVELLING DEVICE 1
007 810 SOUND SYSTEM 1
007 818,819 CD CHANGER 1
007 007 ==============================================================================================================================
007 CHART OF REAR SPRING RUBBER PADS W/STANDARD SPRING SUSPENSION BM 202.022, 202.028, 202.125
007 TOTAL OF POINTS REAR SPRING PAD PAD
007 REAR SPRING BLUE REAR SPRING RED
007 -36 202 324 05 04 201 325 10 44 201 325 11 44
007 37-44 202 324 05 04 201 325 11 44
007 007 45-48 202 324 14 04 201 325 09 44 201 325 10 44
007 49- 202 324 14 04 201 325 10 44 201 325 11 44
007 CHART OF REAR SPRING RUBBER PADS W/STANDARD SPRING SUSPENSION BM 202.018
Copyright Daimler AG, 22/11/11 13:17, EPC 1.28.1.1, DW 11/2011 Delta 2 Page 2
007 -33 202 324 12 04 201 325 09 44 201 325 10 44
007 34-41 202 324 12 04 201 325 10 44 201 325 11 44
007 42- 202 324 12 04 201 325 11 44
007 CHART OF REAR SPRING RUBBER PADS W/SELF LEVELLING DEVICE
007 -37 202 324 07 04 201 325 09 44 201 325 10 44
007 38-43 202 324 07 04 201 325 10 44 201 325 11 44
007 44- 202 324 07 04 201 325 11 44
007 CHART OF REAR SPRING RUBBER PADS " SPORT UNDERCARRIAGE""ESPRIT"BM 202.018,202.022,202.125
007 -33 202 324 09 04 201 325 10 44 201 325 11 44
007 34-40 202 324 09 04 201 325 11 44
007 007 41-45 202 324 10 04 201 325 09 44 201 325 10 44
007 46- 202 324 10 04 201 325 10 44 201 325 11 44
007 CHART OF REAR SPRING RUBBER PADS " SPORT UNDERCARRIAGE" "ESPRIT" BM 202.028
007 -36 202 324 11 04 201 325 09 44 201 325 10 44
007 37-45 202 324 11 04 201 325 10 44 201 325 11 44
007 46- 202 324 11 04 201 325 11 44
007 CHART OF REAR SPRING RUBBER PADS "SPORTS UNDERCARRIAGE WITH SELF-LEVELLING DEVICE"
007 -33 201 324 28 04 201 325 09 44 201 325 10 44
007 34-39 201 324 28 04 201 325 10 44 201 325 11 44
007 007 40-45 201 324 28 04 201 325 11 44
007 46-53 124 324 27 04 201 325 09 44 201 325 10 44
048 A 384233
048 F 369713
120 ONLY APPLICABLE TO:
120 A 202 324 05 04, A 202 324 06 04,
120 A 202 324 09 04, A 202 324 10 04,
120 A 202 324 11 04, A 202 324 12 04,
120 A 202 324 14 04, A 202 324 15 04,
120 A 124 324 21 04
Enjoy!
I've got under just but i cannot feel or see any bumps of any kind, the front measures 45mm in depth and i have no idea on the rear as i cannot see them i'm presuming they are up inside above the top metal plate the spring is in?
Any help or advice on what plates would give -20 to -30mm drop
Jake
The spring pads sit up int the spring cups at the top,
The pimples/bumps are on the outside edge. if you get in there with a torch you should be able to see them.
You should be able to see the fronts by putting the car on full lock, you will need to lift the back up to see the back ones.
There is the little metal washer thing that the spring sits on at the wishbone end, then the spring, then the rubber spring pads on top inside the sping cup.
yeah that's what I've done for the front got right in but couldn't see them at all for some reason? but could measure the thickness of it, I presumed the back was like that I'm presuming the front is 4 or 5 (45mm Depth) and rear 3 or 4?
I'm also presuming once I've swapped these for lower ones i just get the tracking done and it will be fine? are there any other issues i would come across ? or not as its not really lowering much?
Jake
As i said, i have a set of new #1 pads (5mm) for front and back, which i bought for my car without looking at what was on there already!!
If I were you I would try and make sure, what is on there first!
Measuring the thickness of the outside wont tell you what they are, as the measurement is from what rubber is left. The middles of them are cut out so the spring sits in. If you get what I mean!
If you want the pads I bought £ 20 collected or plus postage :thumb:
Also regarding the tracking, I would have the wheels aligned as mine needed doing anyway as the wheels were wearing a bit unevenly, and I had replaced the bottom ball joints.
But if the car drives straight and tyres are wearing evenly, i think it would be ok!
I've just had another look at the front and the springs have 8-9coils each but the passenger side doesn't seem to have a rubber at all? on feeling it or looking? i'm just presuming with it been the diesel with what seems like most extras it will have the thicker in? do you have a pic of yours? so i can see the lowness of the 1's?
Nice! , what size wheels is that on?
and is it just pads only you have used to lower?
The wheels are 17" AMG's
I bought the pads to see if it would lower it anymore, but when i took it apart i had #1's on there already, so didnt replace them.
Hence the new set I've still got!
I Havent done anything else to lower it! Shocks and springss are standard.
205/55/16 P6000's on std 6 spokes i dont know if it will be loo low or not if your on 17's as it looks low! on yours?
The height doesnt change much with 16 or 17" wheels ,
On 16" rim the tyre profile is 55
On 17" rim the tyres are 45 on the front and 40 on the back.
The car will be at almost the same height as the thinner tyres compensate for the larger rim and vise versa.
I have both sets of wheels and neither make the car too low.
where abouts are you in the country, if your local you can come and have a look
Miles away, I'm in Cheshire! don't worry how much do you want posted for the no 1's?
Jake
