gina2201
Hello,
Having had the car for 24 hours, it would appear the rear heated window does not work.
My boyfriend has checked the fuse which was fine, in both the front and the rear. He also checked the earth on the rear window and this was fine too however there is no live getting to the rear elements.
The indicators and windscreen wiper works fine so has not bothered with N10 relay. He suspects the live feed for the heated rear window has potentially broken. He has a Mk4 Golf R32 and this is a common problem with them. The loom breaks between the body of the car and the hatch.
Is this similar with the estate versions of w202's? If so, where should we start looking?!
Thanks.
Thanks.
