i have c200 w202 and the problem seems to be that once the engine has warmed up, the gears do not wanna change up or down but if you put your foot down it revs to about 4k 5k and then it changes gear, it does not really help when your driving at around 15 to 20 mph around down. sometimes a very funny smells can be smelt like sulphur or ammmonia.
also when the problem starts it just holds back like there is a blockage somewhere and if you stop it will stall sometimes.
i have changed the ignition coils, spark plugs, maf sensor.
can it be the egr valve or is it a gearbox problem?
any light on this will be great.
cheers
cheers
