Hi All
Just joined - I wonder if anyone could help with my query - I had a good old rummage via search, but couldn't find anything relating to my problem, which is:
F/n/s wheel 'rattle', when going over a slightly broken surface, from the wheel. I'm pretty sure it isn't any suspension component - had it checked by MB dealer (least said the better..) & good local non-specialist indie - a drop link(?) type thing was replaced, but still the same problem.
A big clue (at least in my rookie analysis..) is the rattly sound goes away on application of brakes (just the merest touch needed) & when the brakes pads were renewed (OEM pads) & copper grease is liberally applied, the rattle goes away - but returns 2-3 months later.
I'm pretty convinced it's something to do with the pads or the pin that fits in the brake caliper - I'm loather to replace the whole caliper & disc assembly & wonder if anyone has thoughts as to cause/cure etc.?
Thank-you.
JollyMan
Thank-you.
JollyMan
