perdikoyla888
- Jun 24, 2006
sunman said:you can hold 2 buttons on the control panel to normalize it. i cant remember which 2
perdikoyla888 said:UPDATE: headrests sorted out
Now two problems left:
1) remote central locking: Confirmed that it is due to faulty antenna amp. Will be replaced this Thurdsay
2) air con ticking noise: Confirmed that it is due to the following error:
for the analog fascia
B15B8 : COMPONENT M2/21 (FRESH AIR FLAP ACTUATOR) IS STIFF OR BLOCKED
Or if you plug in the digital fascia translates to:
B15B8 : COMPONENT M2/19 (LEFT FRESH AIR FLAP ACTUATOR) IS STIFF OR BLOCKED
any ideas if i still need to remove the entire dash for rectifying this fault? What parts are aplicable to this fault that i might need to replace? thank you
perdikoyla888 said:I will remove the glove box firstly as you suggested and see how it goes. But do you know which flap actuator should be the one that causes the trouble? where exactly is located?
Regarding the antenna amp they agreed already to replace it under warranty since I bought it from them this year. Maybe in Australia MB dealerships are less customer oriented...
I hate the ticking noise... Lets hope I can resolve it by removing just the glove box.![]()
perdikoyla888 said:I like you miro beyond the fact you like to provoke me!
