miro
Sorted....Power down seemed to work.
Changing operational modes on the fly does not alter the status in the OCP. A full reboot alters the mode of the unit and then it codes properly.
Hix332race, yes, you will need to get the 3 wire loom. I left the original 4 wire loom connected and fitted the new loom into a spare socket in the OCP.
The relevant part #'s are listed but I would hazard a guess they have been superceeded by now. Have a chat with your local MB parts man, mine was very helpfull in finding a suitable loom.
It may well be possible to utilise the existing 4 wire loom but without meter readings and being confident with the WIS wiring diagrams (from experience these do tend to be somewhat variable in accuracy) I wouldn't recommend it!
Hi
I am trying to do a very similar install in my facelift 04 203. I am slightly confused when you say that you left the original loom connected, I guess you left the original loom connected to the OCP as I guess there would be only one connection on the new combined LRS, which is a three wire connection which is plugged into the spare connection in the OCP. Am I right please?
Yes , you are right
Hi All
Got the new sensor and plugged it to the ocp after changing pins 2&3 around for the loom to be wired straight through. Went to my local STAR guy who was helpful and coded F-SAM to combined HELLA, but could not code OCP as it kept telling RLS is open circuit. Any ideas?
Hi AllI took two photos for you, I should give you an idea about the pin-out of the OCP and RLS .
Hope this will help
