- Nov 22, 2008
- Location
- Leeds, West Yorkshire
- E280CDI SPORTS ESTATE and C200 KOMPRESSOR SE Coupe Auto (1.8 lit petrol)
Since replacing the fuel filter on the above car, I have experienced an intermittent whining noise.
It happens sometimes when the engine is running.
It also happens sometimes briefly for 2 or 3 seconds when I turn on the ignition - Then it stops - Only to start again as soon as the engine fires up.
I suspect the fuel pump.
I cannot understand why it should have started happening following a change of fuel filter.
I've had a look on Nemigaparts and it looks like the pump is in the top of the fuel tank and is a combined electric pump with the level sensor.
Part number appears to be: A 203 470 23 94.
It is not stopping the car from running, but I am afraid that the pump may "pick up" causing metallic particles to contaminate the injectors.
[I've suffered this once before with a cdi high pressure pump - Very expensive ! ]
Has anyone come across this ?
Am I correct in my comments above ?
I'm thinking of getting a replacement unit from Autodoc:
Ridex unit - Ref: 1382F0010.
Any thoughts would be very welcome.
Thanks.
Thanks.
