Hi All,
I am in the process of removing the inlet manifold from my C220 CDI.
I am following the haynes manual which is not too bad however I seem to have a wiring loom and the ATF dipstick tube passing through the hole in the middle of the manifold.
The haynes manual isnt particularly clear when it says about removing the dipstick tube. I have undone the bolt that holds it onto the manifold. Are there any more bolts or does it pull out?
In terms of the wiring I cant see where it goes, is it a case of lifting the manifold up and removing the plugs as they become available?
Thanks very much
Sam
Thanks very much
Sam
