W203 - C270cdi Est Elegance - shaking
mbz124
Hi folks, I have a C270 cdi Eleg 90k estate, it randomly wobbles or shakes from the nsf when doing between 50-70. The front passenger always comments that they have just sat in a massage chair.
I cant see any bulge in the tyres, nor play in front wheel bearing, it will get worse if the nsf wheel hits a bump in the road. Wheels have been rotated to be sure.
I am wondering if its hidden play in the nsf outer tie rod??
Any clues?:dk:
Broken spring and/or shock absorber?
I recently had both replaced on nearside as found faulty after a routine safety check.
The springs usually break at top or bottom ends.
Check wheel balancing also.
