W203 Needing more oil
merc180k
C180K Avantgarde SE Sport
Can anyone advise how ofter I should need to add some more oil to top up the 180k petrol engine? No oil leaks that I can see but the car wants another litre.
Wifes car hasn't needed oil since June service - though it is only a 1.25 petrol engine.
Simon
Just asking, is it the engine management system asking for this,, do you have a dip stick
Washed the car today and got the automatic sensor to check oil. Result was "Add 1 litre to oil" shown on dash.
No manual dipstick.
The engine is supposed to be up to the correct temp 80c and be switched off 5 mins before you check
This is normal for our cars the kompressor has no lubrication of its own and uses up engine oil.
Ahh, didn't know that. Engine would have been about 60ish degrees and was not off for 5 mins.
Have added 0.5 a litre to be safe anyway.
not sure about 80c and all that.
Car should be level and engine switched off for about 5mins. preferably checked first thin in the morning from cold, when it has all settled in the sump
Check it when the car is HOT (when the oil has expanded the most) and on level ground after 5 mins after switch off.
when mine is hot, the dipstick reads nothing at all. or is the dipstick different form the computer readings.
on cold it reads just below the max line
I meant when running sorry. on hot it still reads just below mark but my dad said never check oil while car is running, as oil is circulating and not sat in the sump.
Thats right. Its best to check it when hot as the oil has expanded the most.
My 200K always needs 1litre between services, normally around the 9K miles point. Doesn't sound like you have anything to worrk about.
The manual says 1litre per 1K miles, which is just **** coverage I guess.
So the general opinion is to check the oil using the electronic dipstick when,
1 - car is hot
2 - car is level
and needing oil now (approx 3k before the next service) is normal?:confused:
Mst admit I was a bit surprised to read check from cold.:crazy:
cold or hot is fine to check oil, but do not check when cold if the engine has been run and switched off before reaching normal operating temp.
