W203 Parking light Problem
thefootster
Hi all,
I am having a bit of a problem with my parking lights. The offside one isnt working and I have tried changing the bulb, however, this has had no effect. The warning light is also on on the dashboard. Doe anyone have any ideas on what it could be?
Thanks very much in advance.
Does the rear offside one work?
If not, suspect the fuse.
If it does work, suspect the new bulb or connection at the bulb holder.
A few minutes with a testlight should easily find it.
Not LED bulbs are they?.......
Ted,
Thank you for your reply. No, the bulbs are just standard. It's definitely not the bulb as I swapped them over today and it its exactly the same (the nearside works but the offside doesn't). Also, it's definitely only the front offside that's not working. I'll get a testlight onto it tomorrow in that case.
Thanks again!
Should be pretty straightforward.
Check at the sidelight bulb holder and work back.
Just ask if any questions.
