Just for fun I asked my dealer the price to retro-fit Thermotronic. First he said it couldn't be done (suprise!) then the techs went into a huddle over WIS and came back to say they could do it! Another conflab and came back with the price £8500
When I pointed out all I wanted was the head unit swapped thay said it wouldn't work...
So, no they didn't set it up for me. That was done by Comand.co.uk
I did the upgrade from 580 to 581. What an idiot I was.
The main reason for doing it is that Sydney has a lot of smelly long tunnel with 50m visibility (well it did back then) and the carbon filter deals with that nicely.
Once I had done the conversion I mailed a summary to Richard so they could evaluate the results.
This is what the shopping list is like.
- remove dashboard completely
(now is the time to remove the cat piss smelling heater element and get a new coated version)
- remove the intake housing with blower and replace with carbon filter version and add new stepper motor
- add 4 new stepper motors to the main housing and replace every gear and cog or install as needed.
- remove front fuse box
- remove wipers
- remove wiper motor
- install new harness for sun sensor + pollution sensor
- install pollution sensor and sun sensor
- disconnect dew-point sensor
- install stepper motor harness
- install carbon filters
Put everything else back where it came from.
- install new control panel
- coding
Then for some reason it all works.
To be honest .... without the external sensors it all works fine and the pure air is a real bonus.
Then slap yourself on the forehead because you forgot to install the prewire for parktronic and sound system.
