I have just had a second hand diff fitted with changing the shafts discs hubs etc which has got rid of the whine it had but now it goes into limp 3rd gear.
I have tried disconnecting battery and grounding electronics.
When you start it it goes into gear correctly but once it has changed up it stays in 3rd and will not change out of it if you stop switch off restart it will pull away in first.
Dont know what to check next thought it could be the abs sensors but it was all fine before the diff was fitted.
ANY IDEAS
ANY IDEAS
