W209 Analogue Clock is out of sync with Comand NTG 2
alb001
2006 CLK 330 CDI Sport
My Analogue dash clock has become out of sync with my Comand System Is there a way I can reset it? It is about 35 minutes out. There is no facility through the dashboard menus to do this, only through the comand system with always shows a different time. Does this need to be reset by star?
Many thanks
I thought about doing this, but I was not sure this would work only lose settings on other things. This will definately do it?
It will reset both clocks to 12 and you should be able to adjust them both with them synced.
Set through the cluster and then press the reset button on the cluster straight after.
I cannot set through the cluster as I have no facility. I will have to do it through Comand
On cars with comand the option to change the clock in the cluster is usually disabled so the time synchronises with the comand which gets its time signal via GPS.
Make sure the comand has the correct time zone and time. If this doesnt fix it then you need a trip to someone with STAR;) to enable the menu settings in the cluster to set the time.
