W210 e320 abs bas and ESP fault
braces1977
north wales
mercedes e320 cdi
Just had discs and pads on the rear and pads on front and a new brake light switch. Then I got her stuck in the snow car was fine for about an hour then the lights came on. I know it could do with discs on the front may this be the problem or somthing else. All your help last time was great better than I could have hoped for just hope you can help with this one thanks guys
Get the car put on star,can sometimes be a faulty brake light switch but you've had that changed so a wheel speed sensor could be the culprit,let us know how you get on:thumb:
Yes, please please let us know how you get on. battery voltage ? clutching at straws.
I had that on mine, although not related to brakes it was a corroded wiring loom joing in the passenger footwell.
Hi had battery checked today that's all fine new brake switch working fine next port of call was speed sensor but where is the wire in front passanger ccaallvviinn I will look at that first then back to speed sensor can anyone tell me how to find the speed sensors will be forever gratefull
We have answered this in your other thread about the same subject. You will have to get it checked on a diagnostic machine. Looking at a sensor won't tell you anything.
Hi there
Have a look at one of my early posts as i had the same problem, but was not speed sensors.
What about your speedometer needle is that working fine..I also has ABS, BAS , EPS Light on . but in conjunction speedometer does not work either....i got my battery checked which is fine...now i am waiting to book the car to be checked on star..i have no time for next three weeks to take it to garage..hence just parked on drive..for the moment
