w210 E320 cdi Electric windo sticking
jon_viola
Sussex
S212 E350 CDI Aantgarde Sport Estate
The drivers side on my W210 E320 keeps sticking half way up then continuing to the top but at an angle so that the trailing edge does not seal at the top.
Is there anything I can do about this as a home mechanic?
Cheers
Jon
The window guide must have come loose. Remove the door card and tighten the nuts after setting the alignment.
Thanks for this- is there an easy way to do this?
How do you align the window?
Thanks again
Jon
Once the door card is off, it will be obvious.
Ok thanks- where are the door card screws? All obvious or some hidden?
One behind a cap under the main armrest, one behind the SRS badge, one behind the interior release handle shell which unclips.
After the screws are out prise the bottom away then lift the top off the seal.
Great thanks- will let you know how I get on!
