newbie of sorts here. I've looked all over, but can't find a solid answer. I've had the dreaded ABS/BAS/ESP problem, and replaced the brake switch to no avail. I then came across several suggestions that the fan in the ECU box (behind the brake hydraulic control block) might be broken or stuck, so I decided to haul out the ECUs to look for a fan. There is what looks like a fan at the bottom of the box, but it's more of a weekend job to get at it so I put the ECUs back.
Upon starting, idle is extremely rough, and the engine is hunting and vibrates badly when gear is engaged. It seems to improve a little over time, and seems to disappear at higher revs in neutral. I realise disconnecting the engine management ECU might cause it to lose adaptation data, but how long should I expect it takes to re-learn? And is there a procedure to follow, or can I just drive off? I've double-checked cables and connectors, and everything looks fine on that front, and there are no warning lights or other indications of a fault.
Thanks,
-- Per
Thanks,
-- Per
