- May 28, 2004
- Location
- Essex
- 1984 500SL, 2007 E320 CDI Sport Estate, 1995 SL320 R129
Had to change a glow plug in the W124 Estate last week.
Now it is the W211's turn. Showing the glow plug warning once started for a short while which then goes out.
Firstly I do not have star. Am I right in thinking that if I put a meter from earth to the glow plug centre after removing the cap, I should NOT get continuity unless the plug has gone "open circuit"?
If the plug is good I should get no buzz from the meter when earthed is that correct? as this was the way that I tested my W124 and it worked.
Secondly the plugs are small at 8mm is there anything to watch when doing this job on the V6?
I appreciate that the engine should be hot and the plugs may snap off if you try to undo at more that 25nm according to WIS.
Should I use penetrating oil before I start or just set to with the engine hot?
Am I correct in saying that the tightening torque is 10nm for the glow plugs and should I coat the thread in copperslip? Main Dealer wants £280 to change one plug so I think I need to DIY it.
