thefibreguy
- May 27, 2012
- 2012 Range Rover Sport
Guys,
Have done a search, but just want to confirm something.
I had my car lowered, with drop-links, & then whilst driving home, I noticed the rear of the car started bouncing. I pulled over, & saw the rear had dropped right down, with the rear wheels well in the arches, also the car symbol with the up arrow light came on, telling me to visit mechanic.
I dont think this had anything to do with the work i had done, even though it was suspension related, but because I had never physically raised the car before using the button, I am unsure if it was knackered before, but wanna give the indy the benefit etc. Am taking it back to him on tuesday, but just wanted to check it wasnt something simple.
I have checked the relay is of the Hella type, & that the 40amp fuse (in the same box as the relay is in, under the bonnet) is good. The fronts seem ok, so this problem is only effecting the rear.
When I press the suspension raise button, the LED lights up, & the display did briefly say 'car rising' but it stopped after a few seconds.
Because the LED is lighting up, I would think I have power to the pump.
Can I assume the pump is faulty?
Can anyone suggest any other tests?
Cheers
Cheers
