W211 side brake led cluster
pachanga 231
E280 cdi sport 2007
The LEDs on my drivers rear have failed and I need a cluster, just wondering if anyone has one on here before I apprach dealers on Monday.
Not impressed with these LEDs on the rear , the trunk ones are also prone to failure.
You can purchase the led brake light board from the dealer IIRC £40, 20 minute job.
Thanks guys I think the board will be easiest solution
A lot of hassle and knowledge needed to repair
Very straight forward, tutorials on YouTube if you get stuck.
boards are simple to replace and available from the dealers.
Overall poor design if the whole taillamp has to be removed just to change a bulb
Dealer is quoting 50 plus vat!
Can anyone clarify does the attached board (with 2 wires) come off and dies the new board come with this ?
Different to mine as it's a cls, pretty much the same dismantling proceedure, mine just had to small plugs which you Un plug ( after removing the torx screws holding the board in place ) then just fit the new board plug in, replace torx screws... reassemble the light fitting and good to go, however I did check it was all working before putting the rear lamp back in situ!
Does anyone on here have access to merc database to check a part no for me
A211 820 0611
This is the number on the actual power board where the two wires cone out from
This is held in with 2 screws into the plastic, I removed the 2 screws but it doesn't come out. I'm assuming this is part of the led board That you can remove with the 3 torx screws
If I quote the above number will that get me the led board I'm assuming it will
When I quoted that part number price was 26 plus
When I explain what part I need I get quoted 50 plus!!
Part isn't in.stock either so might have to pay first dint want to be lumbered with part I.don't need
eBay is your friend: 271671999704 (doesn't state which side though).
It's only a quick search, so I am sure there are more out there.
I thought they will be sided
Will That mean different part numbers ?
eBay: 271671999704
Use the pictures for reference.
Never heard of this site
How does it compare to eBay etc servicewise pricewise
56 plus vat from merc just for the cluster
