w211 turn indicator fault ?
Cigano
Banned
Guys dont know wether its the heat , but my comp is telling me my turn indicator bulb is out when there is not and they seem to be flashing very fast , any ideas ? :confused:
Try to replace bulb.
On most german cars, bulb failure indicator will warn you couple days before bulb about to fail. Something to do with incorrect voltage.
It happened on my BMW and MK5 Golf, bulb failure warning light came on while bulbs were fine and couple days later side light bulb failed.
replace what bulb ? they are all fine :confused:
I though only one indicator bulb is flashing fast.
It also can be faulty relay
No bulbs are out , all are flashing perfectly , its just in side its telling me both rear bulbs are out and it ticking fast from inside when ether indicators are used ?
Not doing it today in cooler weather ? :confused:
