derektrotter
- Oct 12, 2013
- MB
Hi All
Was just wondering if anyone had any experiences with Listers used car extended warranties, its administered by car care plan ltd who seem to have ok reviews.
What puts me off is it states all services have to be carried out at MB franchised dealers as manafacture recommends, I know sometimes you can end up with big bills at some services so was only going to do basic servicing (oil/filter) at MB then get an indy to do any additonal work if lots of extras are needed.
Not sure this is possible if I go for the warranty as MB will probably not tick the box "service in accordance with Daimler AG spec" for a basic service if they feel it needs more work, this may be an issue if I need to claim under extended warranty..
Car is a 2011 W212, was not originally considering a warranty however it has stop/start which seems like complex tech, e.g. the transmission has a pump that keeps running when car is stopped, sounds like something that will eventually go wrong knowing my luck! plan to keep car for 5 years or so, currently have the 1 year MB warranty as part of approved used.
Warranty cost is pretty reasonable for a 4 year term, but adding the cost of 3-4 full MB services which will be required as a pre-req may not be worth it, can also go for service plan makes the cost £444 per service which again is on the pricey side, ATF has already been done so will not need doing again for 75k miles which I will not do, not sure what other major pieces would be needed, I'm guessing just cycle between A/B services.
I guess an alternative would be another decent warranty company that do not have the above stipulations.
Thoughts appreciated
