Sherringbones
My 2005 Vito 115 has developed a fault in the right rear unit which has me baffled and means I cant renew MOT until rectified.
When I turn the lights on the right tail light bulb flashes briefly then goes out. Then it will flash again a few seconds later and again for another 4 or 5 times with an increasing time gap between each flash - up to around 15 seconds between the last ones. After that the light stays off.
All other lights work as they should including the right brake light.
I have changed bulbs and swapped them from one side to the other to no avail. I have swapped the entire light cluster unit and the fault stays on the right side suggesting it is not the bulb holder unit.
I have checked the terminals at the connector open circuit and I get battery voltage when the lights are turned on.
I have wired a bulb directly to the relevant +ve tail light terminal (bypassing the tail light housing unit entirely) and the fault remains, however, when I trigger the brake filament from the tail light power supply it lights without flashing. When I try any other single filament 21W bulb (using the tail light 12V supply) they flash in the same manner as my tail light.
I have seen reference to electrical mods causing to the SAM unit; I installed a rear camera some months before the fault arose; it is powered and triggered from the reversing light?
I have pulled the SAM unit out and it appears clean and dry with no signs of corrosion.
I am at a loss as to what to do next;any suggestions would be greatly appreciated!
