Wanted clk 55 Amg w209 engine oil dipstick
Mercedes Benz makes and sells these
One of their dealerships would be able to order you one
Didn't know that there was a engine oil dipstick, just thought that the display tells you when oil is required. What is the part number and where does it go?
Well mine turned up and it was wrong, I think its because we ordered it to where I work which is a garage. If your just a normal customer and apply for what they call their tool to measure the engine oil they will sell you the correct dip stick that you need. Being a garage it was sent to they don't want garages having these tools for service reasons ect so I'm going to have to drive to the local dealership. And as for the display its not worth just using that it has a mind of its own, well mine does anyway lol
My display is fine, well in as much as it says add 1 litre! The only dipstick I know of is for the gear box so where does the engine one go?
I have looked on EPC, the dip stick and tube are listed as not available for the clk 55amg
Mine says that regular then says oil level ok i would rather now for sure with a dip stick just not worth running it low on oil. There is another red cap right at the back above the gearbox oil filler can't miss it.
Might not be under that, they said today on the phone its classed as a tool they use when servicing
where is the tube? the autobox also has a dipping tool, but there is a tube to insert the tool into.
EDIT
OOps, just saw your full reply, over to you steve :)
END EDIT
