fredfloggle
Banned
- Aug 23, 2006
Brabus3.6 said:An update. Over the last couple of days the car has worsened, it will definitely cut out if I don't right foot accellerate and left foot brake. I decided to buy a cylinder compression tester. The procedure I followed was remove all spark plugs, coil lead and fuel plug relay, then screw in and test cylinder compressions.
The results surprised me as I expected low cylinder compressions. The specced cylinder compression for my engine is 10.1:1 up from the 300's 9.2:1. The actual compressions I read from cylinders 1-6 were: 12.5, 13, 12, 11.5, 12, 10.75. So hopefully Ian was correct when he mentioned the valve clearances as excessive clearences will give higher compression. After the valve's were re-seated the all the clearances became too small so I had to loosen all of them, perhaps all too much. I'll re-check them tomorrow. I would have thought if the valve clearances were out the engine would be noisy though as remember this happening on the M110 engines, my 103 runs fairly quietly. Does anybody know of a site that explains clearly how to get valve clearances 100%?!
I have attached a picture of a spark plug that just came out. Unfortunately the picture isn't great but the plug tips look fine however the base of the plug, bottom of the thread is blackened, its smell I cannot make out. Could be carbon or oil fouling. The valves have just been re-seated etc. so I guess it's either incorrect valve clearences or an overly rich mixture?
Thanks & enjoy yourselves tomorrow night!
i think you may mean either BarG or kg/CM2 , the gauge won't read ratio directly - and it is a bum to calculate - you need to know the top ring to piston head volume for a start - it is not just chamber capacity/(sweptVol+Chamber capacity )
Excessive valve clearances won't give high compression ! because of overlap etc and scavenging , peak BMEP is seen higher up the rev range . Try it if you like , screw down a tappet - watch the gauge , and as you start to hold the valve open , the you will loose compression - wind it back the other way , and you will get quite a big valve clearance before you loose compression - all to do with the cam geometry , and air dynamics . Valve clearances would have to be wide open to give the situation you mention , not to mention the God awful noise .
Alternator load - an alternator charging flat out at maximum turbo would draw a couple of HP , but this wouldn't be at idle . The engine is seriously lacking grunt not to be able to turn over the alterator .
Re-Reading this - I am going to take a flyer that when it cooked - you broke at least one ring - yes , it might give a reasonable compression test , but as soon as the ring has combustion gas pressure on it , it can go all over the place . Symptons would be about right - oil passes the control ring and sits in the ring grooves - on the over run it passes into the bores and chamber . On a six pot , one or two pots waffling wouldn't necessarily cause it to shake all over the place - it would tend to pick up when worked as well , but loose loads of power at low revs .
If it is this , get the bores scoped right away - for the cost , send in an oil sample - they can tell you what it had for breakfast . What you don't want is to have a heavy rebore (assuming not linered) because a ring goes to town on the bore .
