BP Ultimate or Shell V Power
Quite a difference though ... BP is 97 RON whereas Shell V Power is 99 RON .. with AMG recommending 98 RON I'd skip BP unless desperate ...
Seems like Esso Synergy Supreme+ 99 now trumps Shell V Power. It is badged as E5 but actually has no ethanol added in most parts of England so will perform slightly better...
Synergy Fuels | Esso
Esso branded service stations have a variety of Synergy fuel blends (grades) to help you get to where you're going. Learn more here.www.esso.co.uk
I have to say, I filled up with Esso 99 a few weeks ago as I was on fumes and it was the nearest station to where I was and I also noticed a positive effect - on economy. I certainly seemed to get more mileage out of a full tank than anything else i've used. Can't replicate it unfortunately as no Esso garages anywhere near my home...I once had to pull into Esso as desperate (was on Tesco Momentum before) and the difference was almost immediately noticeable .. It is more expensive but I am now almost exclusively go to Esso .. with nectar card you get 5p off a litre too so I tend to fill up 75 ish litres at a time.
Don't forget that quoted UK RON rating are a minimum....so chances are it will be higher than 97 anyway as 97 is the minimum it can legally be when sold.Quite a difference though ... BP is 97 RON whereas Shell V Power is 99 RON .. with AMG recommending 98 RON I'd skip BP unless desperate ...
Oop's my mistake it states 95 RONI have a SL 350 2013 and I'm sure it states on the fuel cap 97 RON.
Fair point but needs must when we are running lowQuite a difference though ... BP is 97 RON whereas Shell V Power is 99 RON .. with AMG recommending 98 RON I'd skip BP unless desperate ...
The only thing I could put it down to "coincidence" is that it could be a sensor that is faulty and the Ethanol is triggering it off. I don't know. All I can say is that I'll probably carry on using E5I still see that as coincidence........E10 is 10% ethanol MAXIMUM......in reality its between 5 and 10%......so its just a few percent (1 to 5) more ethanol that the Momentum. Ethanol its self has a far higher octane rating than pure petrol (why drag racers run their AMGs on E85 in the States and you can get Flex fuel kits (basically bigger injectors) to enable most Mercs to run E85 on the road.....its much cheaper over there). If it did affect the running of your car (and I'm not saying if definitely didn't) Id be interested to know how such a small change could flag an EML. Even the cars that should not be run on it could if it was not for rubber/plastic component's not being ethanol proof.....its not that it affect combustion or could damage a valve etc. if there was some intrinsic reason to the E10 to trip the light I think we would be seeing it on lots of makes/models of cars all over the place.....and AFAIK that's not the case.
