When you hold down the rest button..........
zmaster007
Herts, UK
W220 S320L
Hi everyone
In my w220, when you hold down the rest button, you get lots of info about the car - oil pressure, temp, exact RPM etc. but does anyone know what all of th readouts are?
I do not know if this works in other models, may just be the w220.
ps. to change between readouts, press the temperature rise/fall button.
thanks for any responses
zmaster007 said:
Hi everyone
Hi mate,
These are the ones I know of for the W140 (lifted from some website or other a while ago). Dont know if they're the same on your W220 - maybe see if some (like battery voltage) have reasonable values...
I'm sure someone else can give a more complete list:
01: Interior temp sensor
02: Ambient temp sensor
05: Evaporator temp. sensor
06: Engine coolant temp.
07: refrigerant pressure
08: refrigerant temp.
16: carbon monoxide value
17: nitrogen oxide value
18: dewpoint temp.
21: engine RPM
22: vehicle speed
24: battery voltage
Which one is oil pressure on yours?
see below
Does anyone what the values should fall between
Evaporator temp. sensor,
refrigerant temp.
dewpoint temp.
frog1520 said:
Hi mate,
18: dewpoint temp.
21: engine RPM
22: vehicle speed
24: battery voltage
Ill have a look when the car is back at home
any way of getting these readouts if you dont have the digital climate control?
