As a new member I’m 18 posts off having PM’s enabled..!@AMGJames can you enable receiving PMs please as I have something to send over which you may want to try.
You need to ensure you have the latest version. I used 3.0.10Tried downloading the download manager and
Just getting a 'Data medium not found/ Storage medium not found' error with a freshly formatted SD card in the Mercedes download manager.
Europe maps that may well be original (v11 2017/2018).
Shame MB doesn't make this easier - costs them money to take my car in for hours and update it rather than letting me do it myself, with a courtesy car thrown in with no cost to me.
Will call MB and see if there are any other options.
Cheers
Thanks, was a fresh install of the MB Download manager from their websiteYou need to ensure you have the latest version. I used 3.0.10
What year is your car? I don't think it's possible on cars before 2018, dealer only.
Late 2016 thanks. Only other option I can think of is downloading maps from an unofficial source onto USB/SD then asking MB for a pin code. Slightly reluctant to do this in case it messes up or takes 3 hours with my engine running!
Best option is to speak to COMAND.UK they will know what works and what doesn't, even more than Mercedes do.
Re the last bit, maps can be installed from media (DVD/USB/SD-Card) while you drive the car normally.Late 2016 thanks. Only other option I can think of is downloading maps from an unofficial source onto USB/SD then asking MB for a pin code. Slightly reluctant to do this in case it messes up or takes 3 hours with my engine running!
When you stop the car and switch off the engine, the maps update will stop and then resume again on your next drive.
You can listen to the radio while the maps are being updated but you can obviously not use the navigation function.
I found that installing the maps update works fastest off a USB flash drive. On my NTG4.5 the update takes around one hour to complete.
Mine is a 2015 and I did it all at home - as has been mentioned with the latest MB Download Manager it allowed me to just download the maps straight onto a blank SD card - daft question but have you tried running the MB Download Manager in admin mode (ie right click and run as administrator) in case it's a permissions issue not allowing it to fully access the SD card?What year is your car? I don't think it's possible on cars before 2018, dealer only.
OK ignore that link I posted earlier, I get the same error with that old version I linked too.
Try this one which should download the maps as per my screenshot.
MEGA
Just extract that on Windows and run COMANDDownloadManager.exe, username and password are as per the MB documentation in the previous MB link (DLM/DLM)
That should let you download the NTG5s2 map and then you can try plugging that into the car - it won't start doing anything without the PIN so you can make sure the system recognises the map update.
Saying that did Mercedes give you the license code / PIN anyway as if not you're a bit stuck
That's great thanks - now downloading the maps to a USB drive.
Currently not in receipt of a pin... I called my local dealer and they said 'it's not something they can give out... they plug it into the system and it just does it'. Sounds like nonsense to me! Will be trying some other dealers tomorrow as long as I can get the car to prompt me for a pin.
Cheers
It's still in the free 3 year period so the dealer should give the PIN for free at this point though - I got my license for £100 elsewhere when mine was outside of the first 3 years (which turned out to be it's first update even though every Mercedes service sheet had a tick in the box for updating the maps)You should be able to purchase a legit PIN from www.comandonline.co.uk:
