I've replaced all the clear plastic pipes (inc o-rings, the complete pipes come with new rings fitted) between the fuel filter housing and the fuel pump.
Which other o-rings are there that I've missed.
I found a thread a while ago when searching on this subject where he replaced all the plastic pipes (like I did) but still suffering from air in the fuel (like I *think* I am on occasions - though it is a lot better).
However I've tried searching and can't find the thread again.
Any help appreciated!
I'm also considering fitting a ball pump to help prime the system (when needed, i.e. fuel filter change - still a problem even if you fill the filter). This would be taken off a peugeot / citroen.
Anyone know if this contains a check valve (one-way valve) or if would be a good idea to fit one.
I think one of the main problems is that the fuel drains back into the tank a bit over night (especially if parked on a slope) and as the first pump (lift pump) is in the engine bay you have to crank it for ages to displace the air.
A check valve would stop this drain back.
And a ball pump would make it possible to bleed air out with cranking for ages.
