I am thinking of putting a set of "winter" tyres on the car in November time. I have seen that there are !all weather" and "winter" tyres. What are the pros and cons - I can guess but it would be a guess so advice would be appreciated.
so having made the decision that I AM doing this - it is just between the "all weather" tyres and the "winter" tyres - it was the pros and cons between those two options.
I am guessing that the winter tyres are a bit more expensive than the all weathers?, better in the snow and ice, a bit noisier?, wear more quickly?.....any advice much appreciated.
OK, forget all you have heard about noise, low wear rates etc, it means nothing since "cold weather tyres" came into being.
I use Vredestein Wintrac Xtremes, they are as quiet as summer tyres but have twice the grip in cold conditions, not just snow, i.e. below 7C. They also have tremendous wet weather grip & resistance to aquaplaning. I have had mine for a couple of winters now, & they will last at least a couple more. It also means your summer tyres last longer too as they are rested for a few months each year.
All weather tyres are a compromise and are probably only average in more than one type of weather. If you already have spare wheels then a set of summer tyres & cold weather tyres is all you need.
Russ
As stated earlier winter / cold weather tyres are better than summer tyres once the temp drops below about 7 c, and are certainly better tham M and S which, as the name suggests, are a compromise. These tyres have a 'snowflake' to indicate that they are winter / cold weather tyres.
Not necessarilly, they can also have a mountain symbol.
Seconded.
I have Wintrac Xtremes for winter use and can confirm that they are just as quiet as summer tyres, provide quite startling grip in snow / slush and provide a comfotable ride.
A point to note is that these tyres are considered worn out when 4mm of tread remains, although they start with 10mm compared with most summer tyres which start life with 8mm of tread.
Also, depending on your vehicle / tyre you might find that the speed rating of the tyre is lower.
I guess thar once you get down to 4mm they can be used as summer tyres ......![]()
I would go one further.
Buy a tyre with a high silica content and a blocky tread pattern (unlike say..Toyo Proxies) and there's likely to be little difference between that and an all season winter tyre other than the marketing.
I only seem to light up the ASR warning on loose surfaces or mud/wet grass and I got 45k out of the last set of tyres (worn down to the legal limit during the summer for efficiencyI have run winter tyres all year round for many years with little discernible sacrifice to either wear or road holding within sensible limits . Some increase in road noise is to be expected but its not as bad as you might think.
