I'd like to see exactly how they compare WiFi to mobile phone masts, given the following:
Many other pieces of equipment also use the 2.4GHz ISM band - wireless CCTV cameras, DECT phones, some walkie talkies, short-range video senders, and a whole plethora of other 'license-free wireless' devices. Why are people just concentrating on WiFi and not also investigating these other uses of the frequency band; many of which often transmit for longer bursts than WiFi, or don't use DSSS modulation techniques so have higher power peaks at particular frequencies rather than distributing the data and transmit power over a wider frequency spectrum.
- WiFi uses 2.4GHz or 5.0-5.8GHz ISM bands, with a maximum transmit power of 200mW for indoor use. Mobile phone masts in the UK use either 800MHz, 900MHz, 1700MHz or 1800MHz bands, which have to be licensed and they have a much larger transmit power, often in tens or hundreds of Watts, depending on the cell size.
- The higher the frequency, the greater the loss in free air.
- The antennae of mobile phones are frequently closer to soft tissues and organs than the antennae on WiFi devices.
- Modern WiFi equipment intelligently measures the RSSI value for a device and transmits data destined for that device with an appropriate power level.
- WiFi works on the principle of lots of small cells, much smaller than GSM cells. The higher the concentration of the APs, the lower the required transmit power from each AP and from the clients.
- Aircraft landing RADAR systems use the same band as the 5GHz WiFi (802.11a) at much higher transmit powers, yet there is no comment about schools being in the line of sight of these transmitters.
If you ask me, it's just the teachers being scared the little darlings will find out what they're being taught is a load of cobblers!![]()
I'd like to see exactly how they compare WiFi to mobile phone masts, given the following:Many other pieces of equipment also use the 2.4GHz ISM band - wireless CCTV cameras, DECT phones, some walkie talkies, short-range video senders, and a whole plethora of other 'license-free wireless' devices. Why are people just concentrating on WiFi and not also investigating these other uses of the frequency band; many of which often transmit for longer bursts than WiFi, or don't use DSSS modulation techniques so have higher power peaks at particular frequencies rather than distributing the data and transmit power over a wider frequency spectrum.
The classics teacher, who had taught at Stowe for 28 years, claims he suffered from nausea, headaches and a lack of concentration.
Since when we have in UK GSM 800/1700?
Also, not only WiFi measures necessary power to transmit. Mobiles in GSM range did that from day one!
Point with many WiFi cells is partially wrong. Having more than one device with different SSID on same channel *WILL* cost more power output from the device trying to connect - as well as dropped connections.
I believe you're correct there, Orange has always used the 1800MHz band for 2G.I still can't agree to 800mhz for Orange in UK. I don't think anyone in Europe had ever license for 800MHz.
880-915MHz and 925-960MHz, in factDon't forget, that 900MHz is actually 890–915MHz!
880-915MHz and 925-960MHz, in fact![]()
I assume we can agree the mobile mast-cancer thing is the biggest load of scaremongering BS going?
