Skd884
- Sep 13, 2017
- i3
Yes i knew that would happen, specify you only want a yes or no answer and they may oblige....
Also spotted this a few weeks ago, but hadn’t noticed the Disctronic.It's this one: Auto Trader UK - New and Used Cars For Sale
That looks like a nice one. I had a black 2013 C63 estate for many years, lovely car. I like the fact that it has MPS4S tyres. Check water ingress from sunroof, I had water sloshing around under the floor at one point (check carpets). I would also check any leaks from the suspension, geo, and underside damage, because they are used at high speed under full estate loads. Also make sure there is no sign of a misfire, my sporadic misfire took literally years to cure.It’s going through their service assessment at the moment, if there’s nothing horrifying I’m thinking of putting a deposit down.
Just wish it’d had a service in ‘19 when it was MOT’d.
He will, they will be asked to provide proof they are a trader - no hardship.Service dept has had their time with the car- all looks good, suspension and brakes in good condition, no leaks from anywhere - but one of the alloys has cracked and been welded. I'm concerned that I don't know who did this job, how well they did it, and would likely want to replace the wheel.
The salesman is going to contact Mercedes Service about the '19 service, but he's not that hopeful that he'll get an answer.
Buy it if it checks out, Amg have not made a better car since.It’s going through their service assessment at the moment, if there’s nothing horrifying I’m thinking of putting a deposit down.
Someone more knowledgeable will be able to confirm, but I think these are NLA new from MBOn the rims front - would anyone know what a set of four OEM 16 spoke 19" AMG wheels for a 2013 C63 would cost?
As above, no longer available.On the rims front - would anyone know what a set of four OEM 16 spoke 19" AMG wheels for a 2013 C63 would cost?
Fanx, more knowledgeable blokeAs above, no longer available.
I would ask my local main dealer if they could source a set from any of the UK main dealers that may have an unsold set in stock.
Part numbers in the link below.
You may be lucky and get a pristine set from a careful owner from eBay.
AMG Alloys from Alloy Wheels Direct
Find the perfect AMG Alloys for your Mercedes. A huge range of AMG wheels in different styles & sizes. Same day Worldwide Shipping - Alloy Wheels Direct.www.alloywheelsdirect.net
You don’t want those wheels - they’re terrible. They crack like cookies and never look clean unless you like cleaning them on a daily basis. As well as the sunroof I’d check out the aircon to make sure it all works ok - in these cars it’s a well known weak spot and an expensive (front end off) fix. Seems like you’re heart is set on it so good luck and hope it goes well.Thanks chaps. It does seem a little silly in some ways to replace rims that seem to have a very poor reputation for cracking with the same thing, although I do also always want to have the "right" rims for a car.
is there a different rim that people move to rather than replacing the OEM 19's?
I'm test driving the car on Tuesday, if I get on with it then I'll put a deposit down I think.
A superb upgrade to your c55 assuming you like it.Thanks chaps. It does seem a little silly in some ways to replace rims that seem to have a very poor reputation for cracking with the same thing, although I do also always want to have the "right" rims for a car.
Yes c55 to modern e63 was a downgrade.I shouldn’t have sold that - but I did, so no use crying over spilt milk.
I had an E63 for around a year and whilst faster and so forth I preferred driving the C55. Gearbox in the E63 was a totally different and better thing mind you.
I’m hoping the big atmo V8 in the C63 will be more similar to the C55 than the E63.
I agree with the 2 posters above yours, in my 7 year daily drive ownership I had both AC and cam cover issues too! If you can find evidence that they have been fixed, before, all the better.If not the OEM 16 spokes then what?
Ideally close enough to the existing wheels to allow use of the current Michelins.
Nice set of Vossens? (Photo courtesy of badgx)If not the OEM 16 spokes then what?
