16" Alloys hub question
KillerHERTZ
Administrator
Staff member
Cambs
SL63 AMG & C220 CDi Estate
Im currently flogging my old 16" W202 Sport alloys on eBay, ive been asked if I can measure the centre hub to see if they will fit a Campervan.
As its dark and wet, would anyone know already?
These are them:
If you mean the 'centre bore', IIRC it's about 60mm.
I'll try and check for you.
Will
Will
Thanks,
I guess so, the message simple said "can you measure the hub as I would like them for my campervan"
I have no idea about offsets etc, what else would he need to know?
The hub hole should be 66.6mm and the offset will be 35-42mm, but you need to check the wheel itself for that.
Depending on the campervan, assuming it's a VW, the centre will be 57mm for T1,T4 or 68mm for T2,T3.
Wheel diameter (16")
Rim width, inches (xJ)
Offset (ETxx)
Centre bore - as above
PCD - as above
Erm - that's about it I guess.
Will
They only have ten:D, i think he meant stud diameter?
Lynall
Yep it was late.. ;)
5x112 PCD, M12 bolts
At least you were paying attention :D
Will
