190E ariel swop problem
ianturner
Hi I need to replace the ariel on my 190E which is mounted on the rear wing with access through the boot on the left hand side.
The problem is, inside of the boot (on the left hand side) there is a great big piece of plastic trim in the way and I am not sure how to remove it, to get to the ariel to replace it (without causing damage)
Any ideas welcome please
From memory you need to unclip the carpet in front of the petrol tank then pull the plastic down from under the rear wing. It will bend OK then just remove it.
The first time I removed it I thought it would break or something else was holding it but it comes out easily
Hope that helps
Bazza
Hi Bazza thanks for that tip
Thanks Bazza
I will carefully! give that a try
many thanks for your help
