190e auto ok when cold, but when warm it stalls when i try to turn to full lock
when in drive or reverse, even if i turn up idle speed HELP !!!!!!!!
KEN
When you turn your steering to full lock you are increasing the load on the engine as the power steering pump (DRIVEN BY THE POLY V BELT ON THE ENGINE) tries to move the wheels beyond the steering stops. You usually hear a slight whining from the pump when this happens which is a signal to back the steering off slightly. The engine fuel and ignition control units should sense this extra load and compensate for this to an extent to prevent stalling. I would suspect your ignition control unit is not getting a proper inlet manifold vacuum input so check all your vacuum take off points on the inlet manifold side to start with.
