300TE Estate rear light cluster loom.....?
punjabi
Surrey, UK
V230, 300TE
The black plastic bulb holder to the rear driver side light cluster has a snapped locking clip and tends to drop out into the wing void.....I managed to locate a replacement unit from ebay which comes with a long (2ft) wiring loom with an end connector. Any idea where this connector is connected to the main wiring loom as it disappears under the boot panel?
The connector is on the rear inside panel, behind the opening carpet panels, about 18" back, just above the level of the lower trim panel
Nick Froome
www.w124.co.uk
