BigRussJepson
This has probs been partly covered but........
So, I have a 2001 clk 200 komp cabrio with 95000 miles on her.
Last week I came to it at 07.00 am (10 degrees c temp) and she wouldnt crank, the previous night it had been running for at least an hour and i drive her at least 400 miles a week, not due a service for 5000 miles.
I have recently had the clock displays repaired, and the day befor the fault she'd been on trolly jacks for two new rear tyres.
Key inserts, turns, fuel pump can be heard, relay under bonet, all lights as expected, but when key gets to position three nothing happens.
I spent the next day:
Checking all fuses inc those in boot / the ones with the relays under the screwed down tray on the engine bay and those in the cab.
Popped out the clocks and wiggled all the ignition wiring.
Replaced the key batteries.
Ragged the auto gear stick up and down all four positions a million times.
Checked the main battery (12.6v) at rest and put leads on it from my van.
Locked and unlocked many times etc.
Oil level.
Nothing changed.
I left it 24 hours and she fired up like It had never happened.
I have since driven it over 300 miles over several days at all times of day and night and ambient temps, starting and stopping dozens of times, no problms at all.
Today I drove it a few miles, stopped to throw 50 liters of petrol in to her and exactly the same issue.
She is now sat at the fuel station and im typing this.
So ideas please, im going to try to get green flag and then AA to pop a machine on.
Oil temp or level sensor?
Gear box inhibitor?
Battery start inhibitor?
The missus is about to drop our first baby, shes pecking my head enough without this.
Luckily I have the AA full breakdown with up £500 inc vat repair cover, they came through when my c250 died so at least I have that peace of mind but I could do with a push in the right direction.
BTW im just off the M58 near Skelmersdale, Lancashire, UK, if anyone is local or can recommend anyone clued up and genuine?
One last thing, randomly this has happened both times after I have filled up the fuel tank.
Thank you in advance.
Russ
Oil level.
Nothing changed.
Gear box inhibitor?
Russ
