richardgr88
- Nov 1, 2016
- Mercedes CLK 280 Sport Cabrio
Hi All,
With the weather getting better I'm keen to be taking the roof down more often. On the whole the roof has been working really well both going up and down.
Recently though at the final stage of putting the roof down the tonneau cover struggles to close more often than not, from time to time it will close ok. When it does close ok it seems to go with a bit of a clunk. The tonneau has no issue slotting back in when putting the roof back up and the roof locks in place ok above the windscreen.
I have checked and I can't see any obvious hydraulic fluid leaks but have noticed the fluid is a mm or 2 below the minimum line on the fluid reservoir.
Do you think it could be the fluid being low causing this problem?
Also because it is just below the minimum mark is there a high possibility of a small/slow leak being present somewhere?
I am struggling to find MB 343.0 spec fluid which I believe it requires. I've found the below Ravenol product on Amazon. Would this be the correct fluid, it says it meets MB 343.0
I'm guessing it's a case of undoing the brass looking nut and filling up with a syringe or pipette to the maximum.
