Hi all,
OK, I'm going in the right direction.
After much testing with a Multimeter and finding that the sensors seem to be working OK, but one thing I did notice, when doing the rotation test the front wheels gave a slightly different reading than the rear. The front sensors started at about 1.083 and when turning the wheel the numbers did change
a bit, but the rear, again starting off at about 1.083, when spinning the wheel the numbers changed
allot more.
Anyway, I decided to remove the front sensors to check that they were earthed correctly and in doing so realised a mistake I had made when I reassembled the front hubs after an overhaul of all the suspension, bearings etc, the sensors were bolted on the wrong side of a bracket (this bracket acts as a shield and holds cables and flexi brake pipe in place), when bolting on a sensor to the hub carrier it goes directly onto the hub carrier and the bracket on top, not the bracket first and then sensor
So, my problem was that the front sensors were to far from the reluctor ring hence why my speedometer was acting up and ABS light on.
But, now my speedometer is working fine, but my ABS is still not quite sorted yet. When I test drove my car the ABS light went out (I thought, YES!!) :bannana:, I drove down the road but unfortunately the ABS light came back on again. It seems to be doing this a few times, start the car ABS light goes out, drive forward a little light comes back on.
I feel I'm almost there, how sensitive are these sensors and their positioning?
